Root Unroot 2.2
iyvin14
hi everybody
i want to root my optimus but i just wanna make sure that there ia a way to unroot it if i dont like it
If you use Z4ROOT...
you will have the option to unroot once you are rooted
With z4root you can even "temp" root for that one session.
but once I did that a few times, I perm rooted and never looked back. All root does is make you administrator so you have total control over your phone. It does not do anything to hurt your phone.
Even with root, you ALSO need some sort of file manager like Root Explorer to go see all the files and folders in your system. (unless you are advanced enough to use terminal line commands). I'm just saying root is the first step. So, there's really no reason you would want to "un-root".
But yes you can, if you want.
