Root UNROOT: Help, Can Pay $
DCBlueStar
Hi all. I need a little bit of help.
If someone could please point me into the correct files to unroot my phone, I'd greatly appreciate it. There are so many files and terms that I am getting mixed up.
If anyone would be so kind as to help me out step by step, I'd really appreciate it.
Could even offer up a couple bucks ($10 or so) to someone who can help me get my phone back to stock mode with the original apps (mine are gone thanks to windows copy/paste feature).
Email admin@dcbluestar.com
I must not be doing something right because I haven't gotten the stock apps back.
I was following the CWM steps but it didn't say it was for unrooting so I stopped. They need to make that more clear in their threads.
Follow the link the above poster gave make sure u have CWM installed and downlad the nandriod back up to SDcard then boot into CWM and do a factory reset and a davlik wipe restore ur nandroid bk up then do the direction for the stock recovery and u should be back to stock
You can use CWM for lots of different things, when you do the stock nandroid it will be an unrooted version (and should have all those apps in as well). The steps the previous poster went through will get your phone back to stock.
But when I press "Flash ClcokworkMod Recover" my phone's model doesn't show up in the list.
The only choices are:
Huawei Pulse Mini
Dell Streak
Huawei Pulse
Commtiva Z71
Geeksphone ONE
Spice MI700, Commtiva Link N700 and more
Huawei Ascend
Huawei U8220/U8230
Huawei Ascend 2
Micromax A70
Trying to return my phone but I noticed when I put it up I was accidentally holding the vol buttons and the power button and noticed that CWM came up...
How can I stop it from doing that so they can't tell it was rooted?
I think I got that too... is it normal when you remove the CWM recovery.img and replace the new stock one, and try use the vol buttons + power that it just sticks on vibrate?
At any rate, the orange CWM menu doesn't come up anymore.
