Born2Snoboard1
So I rooted the stock 2.1 awhile ago, uninstalled a bunch of stuff i shouldn't have so then back to stock out of the box 2.1. I then deleted the update.zip off the phone because I figured the phone had not installed it with the fresh 2.1 flashing and showed no superuser. I'm now running 2.2 rooted by the Z4 app. When I try to reinstall packages on the boot menu I get "failed to open /mnt/interal_sd/update.zip then it aborts installation.
How can i fix this so I don't get this annoying message. It doesn't affect the phone's performance I just want to be able to reinstall packages. I have the original update.zip for 2.1 in my e-mail so I can easily put it back on the phone, but won't that mess up the phone because it's designed for rooting 2.1? If I need to flash back to 2.1 and then uninstall or something I can do that. Help please. Thanks.
