ScottNY845
checking "PB" file now
ok, removed battery...pressed VOL DOWN and END and still says no image or wrong image...
system is unzipping now updating
No clue...that was the first screen and then when it was checking the "PB" file it was ok...looks like this worked...
Now a question...will she get the OTA update or is this the latest version of firmware?
Setting up phone now...looking good so far...will keep you posted...YOU ARE THE FRIGIN MAN...I am naming my third child after you...
Hi everyone!
I have to warn everyone...I don't pretend to be knowledgeable about rooting. I rooted my eris back in August and flashed the XTROM that was out back then and that was it.
I've been using the phone like that ever since. Now, I want to trade it in to Verizon (I already have a confirmation email for $132 from before they changed it).
Now here's where I have trouble. My trackball has ALWAYS worked until I tried the unroot process. Can anyone WALK me through REALLY slow how to unroot with no trackball. I can maybe do it with the usb to the pc???
Thanks in advance...I'm really stuck![]()
Wow, old thread. I would actually follow the instructions in Scenario 3 here: http://androidforums.com/eris-all-t...2-custom-recovery-trackball-not-required.html to install a version of Amon's Recovery that does not require the trackball.
Great! I will try this...thank you!
My trackball is now working.
[ROM][10/20/2010]FlashBack21 v1 -Return to Factory Stock - UPDATED - xda-developers and am about to perform the wipe. Am I on the right track?
OK, so when I select wipe it gives me 5 choices...
Wipe data/factory reset
Wipe Dalvik-cache
Wipe SD:ext partition
Wipe battery stats
Wipe rotate settings
Which one do I pick?
TIA
1) Make sure your phone is fully charged
2) Get the "FlashBack21" ROM (.zip) file onto the top-level folder your SD card
3) Verify using a file manager on the phone that it is the exact # of bytes indicated in the "FlashBack21" ROM page. If it is not, you made a mistake downloading it or transferring it from the PC
4) Boot into recovery and perform the "Wipe data/factory reset"
5) Flash the ROM from the main menu of Amon_RA.
6) Take your phone back to Verizon.
Ok, so I completed up to step 4. Do I sign back in with my gmail account to get to Amon_RA on my sd card? I know...I'm one of those people who should never have rooted in the first place![]()
No that's unnecessary. You actually should wipe/data factory within Amon's Recovery (it is an option in the Wipe menu) and, without restarting the phone, go back to the main menu, go to the Flash menu, and flash the Flashback21 ROM. When that is done, then you can shut down the phone (you can restart if you are really curious to see that it is truly reset) and return to Verizon.
. I restarted and I get an error message "Sorry! The process com.htc.bgp has stopped unexpectedly. Please try again." with the activation screen behind. Is this ok? Thanks again!OK, so of course I'm the curious type. I restarted and I get an error message "Sorry! The process com.htc.bgp has stopped unexpectedly. Please try again." with the activation screen behind. Is this ok? Thanks again!
And when I try to boot into recovery, I guest a pic of the eris with a red triangle with ! inside.
The error message is a little bit unusual, but based on your second comment ("eris with a red triangle with ! inside"), it is apparent that you have successfully unrooted your phone.
Time to send it back to Verizon now, I suppose.
eu1
