JB in AZ
Android Expert
hey guys...been trying for hours to unroot.
hboot 2.02,
baseband 2.15.00.11.19
software 3.70.651.1
PRI 1.90_003
Rooted with unrevoked 3.3 (i think it was 3.3) Previoulsy had flashed the combo update to get the latest radios etc, to run Calkulins EViO2 v1.8 rom, which was running perfectly. Followed the steps in the Rooting for Dummies guide to unroot. Flashed the s-on tool, it now shows s-on. Downloaded and renamed the file to PC36IMG.zip...not zip zip...flashed the PC36IMG.zip, (hopefully the right one, selected the one for hboot 2.02) and it says checking, there is a progress bar, (running amon RA 2.1.1) then it stops, and never gives me the choice to say yes or no...rebooting just gets me back to the custom rom I had previously installed. I even re-downloaded the PC36IMG file in case I got a bad download. What gives? Thanks for any help. Exhausted, going to bed. I need to have this unrooted on Friday.
I suspect that I may have the wrong PC36IMG file, I chose the one for HBoot 2.02...
hboot 2.02,
software 3.70.651.1
PRI 1.90_003
