Root unrooting help
Hendoe
Hello I have a wildfire s on the metro network and need to unroot it. Itryed unrootlock but to no avail. Please and thank you
I don't think it will save you because unlocking the bootloader does wave off the warranty. However I have heard that for some few people it has worked (Guess the guys didn't realize it was relocked or something). So I would say Maybe if you are very lucky you will get away with it :)
[Guide] Re-flash stock ROM (RUU) after bricking a rooted device thread will give you the process on how to relock:
. Boot the phone into bootloader (power off, hold down volume and press power) and highlight FASTBOOT using the volume rocker and pressing power. Then connect the USB cable. You should see FASTBOOT USB.
6. Relock the bootloader using the following command:
Code:
fastboot oem lock
