Root Unrooting Triumph?
I need to have my phone replaced and its obvious that my phone is rooted and Ive already tried to just get Best Buy to replace it but they wont. Anyways, I cant figure outhow to unroot it. I cant find anything on the internet on unrooting the triumph. And what I did find was confusing and didnt explain in depth enough. Please help! I dont want to pay another $200 for a new phone!
how is it obvious that ur phone is rooted. rooting does not change the appearance of the phone unless you flashed a custom rom. to unroot your phone depends on how u rooted ur phone. http://androidforums.com/triumph-all-things-root/455603-guide-rooting-your-motorola-triumph.html here are ways to unroot your device if you had rooted it in that way.
But if you have a custom rom on your phone and you have your stock backup then do that. Or go to this link http://androidforums.com/triumph-al...de-100-stock-motorola-triumph-newb-proof.html.
If you rooted it with gingerbreak then all you need to do is use gingerbreak to unroot it.If you flashed CWM recovery and a custom ROM then you need to go into CWM and flash back the stock ROM (nandroid back up if you made it or the link on this page has one) then go into incoming download mode to flash the stock recovery.
