Unwanted Applications
ShiKaiSheng
What applications can I use to remove unwanted pre installed apps in my x10 mini pro?
and how do i go about removing them?
I just updated it to 2.1 eclair
Anybody help!!!:confused:
You would need to root your phone and then install Titanium Backup to remove the apps you don't want. Rooting voids your warranty but there are threads on the go at the moment about rooting your mini so have a browse and gather some info so you can make an informed decision.
you would need to root your phone and then install titanium backup to remove the apps you don't want. Rooting voids your warranty but there are threads on the go at the moment about rooting your mini so have a browse and gather some info so you can make an informed decision.
thanks!!!:)
