Help unwanted photo albums
Hi there
I have some unwanted photo albums I cant delete!
They have this logo in the bottom corner.
Can anyone tell me how to remove them.
They're from Picassa, do you use that? If so, log in and there'll be some way to un-sync them or go to Settings > Accounts and un-sync from there.
If you don't use Picassa, they're probably just sample/stock images. Find the Picassa app on your phone and disable it, that should do the trick :)
I removed the sync for picassa in my accounts to no joy.
I downloaded a picassa tools app, that didnt work.
So I had to log on to my google picassa account on a PC and delete all the photos mannually. They have now all gone.
Damn this syncing!
Thanks.
