Root UOT Help
So I am dabbling in using UOT for the first time and I am getting the "E:error status 0" when flashing the zip. I see there is a work around listed on the UOT kitchen site. I seem to get hung up on step one....where do I find this directory that has "META-INF/com/google/android/update-binary"? Much appreciated in advance
Savoxis posted very recently that what you ought to do is go to the velocity 1.1 zip and in that directory copy the update binary (search for the thread and double check) and replace it in the other zip.
Navigate to the update binary in the 1.1 zip and go to the same directory in the uot file and replace the one thats currently there. Then make sure u disable file verification or sign the zip file yourself
