barefootpilot
Made several custom themes based on the CM7 theme chooser 'Green Hornet' theme. Tried today to make a new one using the Hoolm battery and it failed. I uploaded the same .apk that I've used every time in the past. Anyone know if there's an obvious issue? The options on the file upload page seem to have got a whole lot more complicated recently...
Error log: from UOT:
Decompiling themer.apk UOT-06-22-09-35-1
I: Loading resource table...
I: Loaded.
I: Loading resource table from file: /home/mendozinas/apktool/framework/1.apk
I: Loaded.
I: Decoding file-resources...
I: Decoding values*/* XMLs...
I: Done.
I: Copying assets and libs...
Compiling themer.apk UOT-06-22-09-35-1
W: Could not find sources
I: Building resources...
/home/mendoza/port5/data/working_dir/UOT-06-22-09-35-1/th_dec/res/values/styles.xml:118: error: Error: Integer types not allowed (at 'android:measureWithLargestChild' with value '1').
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, -F, /tmp/APKTOOL6410778714222207267.tmp, -x, -I, /home/mendoza/apktool/framework/1.apk, -S, /home/mendoza/port5/data/working_dir/UOT-06-22-09-35-1/th_dec/res, -M, /home/mendoza/port5/data/working_dir/UOT-06-22-09-35-1/th_dec/AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:193)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:301)
at brut.androlib.Androlib.buildResources(Androlib.java:248)
at brut.androlib.Androlib.build(Androlib.java:171)
at brut.androlib.Androlib.build(Androlib.java:154)
at brut.apktool.Main.cmdBuild(Main.java:174)
at brut.apktool.Main.main(Main.java:59)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, -F, /tmp/APKTOOL6410778714222207267.tmp, -x, -I, /home/mendoza/apktool/framework/1.apk, -S, /home/mendoza/port5/data/working_dir/UOT-06-22-09-35-1/th_dec/res, -M, /home/mendoza/port5/data/working_dir/UOT-06-22-09-35-1/th_dec/AndroidManifest.xml]
at brut.util.OS.exec(OS.java:83)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:191)
... 6 more
