amazin1988
how do u use it ? i start out ok but i dont know what i need to down load so it can work can i have some help please
thank u both i got just working on how to make my phone come to life now thank yall very much
you welcome. a little thank bottum wont hurt... lol j/k (not, im serious). lol naw
well yeah, im glad you are up and running, get in mind that the icons for status bar expect the battery will not appear unless you have background data enable...
thanx Bro, easy intsruction to follow. did it & worked...As star said you need to upload systemUI. All and framework-Res.Apk;
systemui.apk is located in /system/app >
Framework-Res.apk is located in /system/framework >
Now, if you have root explorer or any app that can access the system files then you can copy those files (systemui and framework-res) to your computer and then upload to the upload section of uot kitchen. At the right side of the page you'll notice a option where it says "upload system files" you click there and then upload the files that you have copied to your computer (systemui and framework-res). Also make sure you have the update-binary set to EMMC since that is the comparable binary for the esteem.
Notice all this is done after you have chosen and selected all your desired mods and customization. Also when choosing mods and stuff make sure you select the hdpi screen size because that is our phone resolution. Cheers and good luck.
Ohh yeah. After you submit the work you "cooked" . Then wait for your pickup at the pickup page. It might take some time, be patient. To install it to the phone you simply flash the uot blah blah 1-7-1 .zip file through CWR as if you were to flash a ROM. No wipes required so you dont need to wipe anything.
Good luck!!
does any one knows if one an uot kitchen file has been flash, if there is a possible way to return to the phone stage prior to the uot kitchen file being flash?
this is using a stock out of a sprint store phone
Hi I'm going to use this later today but when I flash it in cwm what do I do first?
I've used uot for a while..on the Esteem when changing the noification pull down settings (header, notifications, power settings icons, notification background, etc) nothing gets change. Whereas mostly everything else will.
Has anyone else experienced this on the Esteem?
I'm selecting emmc binary option. Should i use MTD? or would that not even change the reason why the notification pull down menu graphics don't change?
Anybody have any advice or tips?
Thanks!
using UOT for the first time tonight. any tips?
make sure you back up your phone first just to be safe![]()
