varun.chitre15
Android Expert
Here is the second update of build.prop
Procedure is same as the first update
http://www.4shared.com/file/AQxPDgKy/build_3.html
Changelog:
1.Added one kernel tweak
2.Deleted some repeat tweaks and corrected mismatch in scripts with build.prop
3.Added two tweaks to increase performance slightly.
4.Decrease dialing timeout delay.
5.Decreased proximity delay.
Note: This is tested by me and currently I m using it so there are no risks at all.But still if anyone want to backup Olds one then they can simply add .bak by renaming it.
Changelog:
