Android Version: unknown (HTC Desire S, Germany)
Network: BASE
Taskiller Used?: No
[Optional]Are You rooted & which Rom: No
Issue:
I was notified that a system update is available and I installed it (unfortunately without backing everything up before). Something must have gone wrong - afterwards, the phone couldn't boot anymore, it wasn't a boot loop, it just got stuck at the HTC logo screen.
So I used Vol down+Power to get into HBOOT, and I was presented with the recovery and factory reset options.
I expected the recovery function to be different from the factory reset in such a way that it wouldn't touch the user data but just fix the Android system.
So I downloaded the appropriate RUU exe, extracted the ROM ZIP, renamed it to PG88IMG.zip, placed it on the SD card, and rebooted again. It found the ZIP package and I was asked whether I wanted to start recovery and I said yes, and during the process there was a message that it's clearing user data...
The phone boots up fine again, everything is new, all settings are lost. Why does the phone recovery clear user data and cache?
The problem is that contacts and messages were on the internal phone storage. When I google for methods to fetch contacts and messages from the phone, I always find apps which can be used to backup these files. However, the phone wouldn't boot anymore, so I couldn't install or run an app.
My question is: Would it have been possible to rescue the internal phone data when the phone isn't able to boot anymore, i. e. directly from the HBOOT menu? There wasn't an option like "Backup internal phone storage to SD card" which probably would have solved the problem. But maybe it could have been done via a USB cable and fastboot or adb? I have no idea, and I would appreciate your input very much.
I know, I should have backed up everything. I would just like to know whether data could have been rescued and whether it may still be possible to recover the data now.
Thanks a lot,
Michael.
Network: BASE
Taskiller Used?: No
Issue:
The phone boots up fine again, everything is new, all settings are lost. Why does the phone recovery clear user data and cache?The problem is that contacts and messages were on the internal phone storage. When I google for methods to fetch contacts and messages from the phone, I always find apps which can be used to backup these files. However, the phone wouldn't boot anymore, so I couldn't install or run an app.
Thanks a lot,
Michael.
