Root UPDATED 11/23/12: {([ROM])} Android World Order! !OVERCLOCKED 2.3.6!
twogbsd
Android Expert
Introducing:
Android World Order v1.0.1
The first Admire Rom with The AROMA Installer
This is still a work in progress!
Not all features in the AROMA installer work, but most do.
Android World Order, is the first rom for the Samsung Admire that is based off the Offical 2.3.6 and has the AROMA installer. What is the AROMA installer? Its a special version of the updater-script and update-binary that allows you to use your Touchscreen while in recovery. Thats right, you can use your Touchscreen while in CWM. So basically, the AROMA installer turns CWM into CWMTouch. The AROMA installer allows you to install the apps you want. Flash APNs. The possibilities are endless!
This new version of Android World Order is available in 900Mhz with Spz0's Kernel EXT4 Version and 800Mhz with Stock 2.3.6 RFS Version, with a Metro version of both and a Cricket Version of both, as well as an option of adding nTelos APNs.
What works for MetroPCS?
Everything :)
What works for CricKet?
Everything but MMS and some rare cases of bluetooth droping connection.
Download!
AWO_AROMA_v1.0.1.zip - 127.64 MB
BUT WAIT 2GBSD! Why iz der only one downloadz?! j00 sayd ther waz fuor versionz!
With the AROMA Installer, you can pick what version you want while in recovery :D
WARNING FOR CRICKET USERS!
When you turn on the phone and turn it off you will see the MetroPCS Boot animation and Shutdown animation. I have not fully de-metroed the Cricket version yet.
How doez i install dis ding?!
For the Metro/CricKet EXT4 version:
1. Download the .zip and place on SD Card.
2. Boot into CWM Version 5.0.2.8.
3. Select Install From SDCard.
4. Find where you put the .zip file and install.
5. Wait for the AROMA Installer to start.
6. Select the theme for the AROMA Installer.
7. Accept the Agreement and read Changelog.
8. Select 1 for Metro or 3 for CricKet.
9. Pick your extra apps then wait for AROMA Installer to finsh.
10. REBOOT AND PROFIT!
For the Metro/CricKet RFS version:
2. Boot into CWM Version 5.0.2.7.
3. Format /system and /data
4. Mount /system and /data
5. Select Install From SDCard.
6. Find where you put the .zip file and install.
7. Wait for the AROMA Installer to start.
8. Select the theme for the AROMA Installer.
9. Accept the Agreement and read Changelog.
10. Select 2 for Metro or 4 for CricKet.
11. Pick your extra apps then wait for AROMA Installer to finsh.
12. REBOOT AND PROFIT!
If your on nTelos:
2. Boot into CWM Version 5.0.2.8 for EXT4 or 5.0.2.7 for RFS.
8. Select CricKet or Metro EXT4/Version (Doesn't matter which one).
9. Pick your extra apps then scroll down and select nTelos APNs.
Screenshots!!!
AROMA Installer Pictures
Original post:
Introducing:
Android World Order
The first EXT4 rom based off the Official MPCS 2.3.6 Update.
Features
Zipaligned
Busybox
Init.d Support
A2SD Support
EXT4 Support
Spz0's OC'ed 900Mhz kernel
Deodexed
And Eye Candy ;)
Downloads
AndroidWorldOrder.zip - 106.49 MB
Instructions
1. Download AndroidWorldOrder.zip and place on your sdcard
2. Install CWM Version 5.0.2.8 (Skip if already installed)
3. Boot into CWM 5.0.2.8
4. Select "Install zip from sdcard"
5. Find where you put the .zip and install.
Notes
This is a self mounting and formatting rom.
There is no need to mount /system or /data nor is there a need to format them. :)
This comes pre-overclocked at 900Mhz.
This is not the final release. Only a beta to see how you guys like it :D
Credits
Killcmd for his deodexed version of the 2.3.6 update :D
Spz0 for letting me use his kernel :adore:
My brain for finally realizing my errors in my alpha builds :p
Screenies!
This is exactly what i wanted. The 2.3.6 update with ext4 support. I'll definitely test this out later today but for now I sleep. Although android world order sounds creepy lol
Lol 0.o I think I'll change the name later :) how does The Admiral Entity sound?
Sent from my SCH-R720
Excellent work, 2G. I, too, have been waiting for an EXT4 2.3.6 rom. I am downloading now and will flash it after modifying it. Looks great, thanks :D
First off, I love the screen animations, but they might be what is slowing my phone down. I checked CPU Master and I am running at 900Mhz and its still a little laggy. Other than that its nice. I installed most all my apps and still have 119Mb free. I'm definitely digging the icons in the status bar, especially the battery indicator. I like the background but might change it to something else after a while, but I do remember the fifth of November, lol.
All in all its a nice rom, I might stick with it for a while and might stick it on my wifes phone.
Is there a way to turn off animations, by chance?
Edit: Jay-kay, I found it, set it to "Some Aminations" and now it seems to run a LOT faster. :)
This doesn't work on my spare admire. Freezes up at metroPCS. Well it works with my main admire so that's cool
Hey
Great rom...I have 2 questions...how does this compare to lithium and what is the difference between ext4 and other file systems?
Thanks
Android Lithium is a mix of 2.3.4 and 2.3.6 overclocked with req's kernel and tweaks.
Android World Order is full on 2.3.6 and overclocked with Spz0's kernel and tweaks.
Heres a good analogy I found on XDA regarding EXT4 vs RFS file systems:
Why would you use NTFS partitions in windows instead of FAT32? Because NTFS is faster in input and output of data transfer.
Same with EXT4, it's faster with input and output.
RFS is more stable however...
Grr. Can you make a lazy version of this? I had to switch motherboards on my admires so now the one i use is the one this won't flash on.
I've been trying to theme the system Ui but for some reason I try flashing it but does not take effect any help?
Here is my take on it:
A bit laggy.
Way too many animations.
Love the launcher.
A bit of a battery hog.
Need Link2SD support. (I cannot get it to work.)
Well thought out.
Actually on these phones ext3 is the best fs. Most benefits of ext4 but no journaling faster.
If I still had my admire I'd probably be working on an ext3 kernel to replace my ext4 one you're using in this rom.
Sent from my DROIDX using Tapatalk 2.
A bit laggy.
Love the launcher.
Well thought out.
It has link2sd support lol I got it to work. And you can just turn off animations or use uot to flash different animations. I didn't notice the battery thing but I thought 2.3.6 lasted longer.
It's funny I have my sd card partitioned with ext3
i recommend that you keep the overclock kernel but set it so when you flash it its set to 800 or perphaps even lower so some admire can actually boot up
