Help Updated 2.3.4 problem
Daz1er
Hi all,
On Friday I updated to 2.3.4 and everything software wise seems fine however, I'm on Voda network and for some reason now I it keeps dropping my phone connx!
Has anyone else suffered with this
Haven't had a single call dropped before or after the update mate. Are you in a particularly low signal area or somewhere where you often jump between 2g and 3g signal?
Thanks for your reply.
It was all fine before the update which is why I ask!
I have 2 other phones that are also on Voda and both of those still show a strong signal.
hmm that's really odd then. It's a long shot but try taking the cover, remove the battery for 10 secs and just give all of the electrical contacts a brush off that connect the case and the phone itself as the antenna are built into the case i believe, and may be getting a poor connection?
