Has anyone tried any speed script things like supercharger on this phone?
My theory is: On LG ICS the radio reads the ERI info and seems to straighten itself out, Well since there is no ERI.xml in the system/etc it has to be read from the radio/modem. The only way for the RIL to read the eri is through a special hook like this:
That's a completely different file.d2a, the ERI.xml is located in the framework-res.apk under /res/xml when the .apk is decompiled. It looks like the CM9 build (quattrimus) has the same ERI.xml as the ICS leak. The ICS leak and CM9 ERI.xml are different from the GB ERI.xml.
Not sure if this helps.
