Root Updated CWM won't install ROM
Toddw
So I made the mistake of updating CWM to 3.0.0.8 and now I can't load ROM. I've had to go back to completely stock and had a hard time getting root. I tried to revert back to old CWM in Rom Manager but it says Encountered error trying to download. How else can I either get back to old CWM or install another EB01 ROM?
Go to androidcentral and get the all in one eb16 odin pack. Has cwr and its prerooted. Flash via odin and your done.
Bob's direction got me back on EB01 and running again though for some reason it's not quite as fast as it was before. I know Quadrant scores don't mean a whole lot but it's down from 1400 to 850. I installed the EB01 voodoo kernel but how do I know voodoo is actually active?
You probably never went into the voodoo menu within CWR to activate it. During your initial reboot after enabling voodoo you'll hear a female voice updating you on the conversion progress...it'll take about 5 mins. If that doesn't sound familiar, you didn't convert.
I actually had gone in and activated it but I didn't listen to her voice tell me that there was not enough room on SD card so I went in and made some room. That did it. I'm back running EB01, voodoo, and with a fast phone. Thanks for all the help.
Once I've installed Super Clean using the method above the phone is running fine. I'm having trouble installing any other ROM though now. I tried flashing Black Hole, which is what I was originally on, it booted up fine but started Force Closing every app and continued that essentially locking up the phone. I reflashed Super Clean with Odin and it's OK again. Can I not flash other ROMs now? Is there a difference between EB01 and EB16?
