Updated Market for 2.1
Nirob
THIS ONE IS 2.2 STYLE MARKET... CHECK THE 2ND POST FOR 2.3 STYLE MARKET WHICH IS NEWER... THANKS!
This is the Update Version of Android Market for 2.1... (Note that this is not the Market that Google just recently released, that one is for 2.2)
-New UI (About, Comments & Related tab added)
-Auto-Update of Apps (You select which apps will be updated automatically when an update is available)
-Update All option...
-Download starts instantly! :D
Just enable Unknown Sources (Settings> Applications & tick Unknown Sources) & USB Debugging (Settings>Applications>Developement & tick USB Debugging).. Then Download this: https://dl.dropbox.com/u/16922381/Market.apk & install... :D
This one is Newer(2.3 Style): http://www.mediafire.com/?jmpno1wopd99jus
-New UI (Carousel on the Home and Category
Screen, New Categories)
-App info in One page
-Content Rating (like All, Pre-Teen, Teen and Mature)
Before installing, go to Settings>Applications>Manage Application & find Market(If it's not there, Press the hardware Option button then Filter>All) then select it and click ''Uninstall Updates'' if it's there...
Now, install the apk with Unknown Sources & USB Debugging enabled...
Before installing, go to Settings>Applications>Manage Application & find Market(If it's not there, Press the hardware Option button then Filter>All) Select it and click ''Uninstall Updateds'' if it's there...
plz plz plz i am noob soo plz help what do u mean with the hardware option button???
and
and how do we install apk files with the unknown sources thingy ??????:confused:
and
Hardware option button is the button on top of the physical Answer/Yes button...
To enable Unknown Sources go to Settings>Applications and tick 'Unknown Sources' & to enable USB Debugging Mode go to Settings>Applications>Developement and tick 'USB Debugging'.... Then install the apk with your favourite File Manager...
Hi guys i have an LG GT540 with the official update (2.1)
And my market Has the "starting download" issue
I tried your's but it still don't work
Do i need to be Rooted or something?
At first, 1-2 downloads are likely to cause this problem... Try canceling download & install again, if it doesn't start then cancel-install again... Give some time after cancel-install...
If you are using the 2.2 style one, then it'll hopefully will fix by itself... And if you are using the 2.3 style one, then during download stay on the App page till it's installed...
I am trying to download the file from http://www.mediafire.com/?jmpno1wopd99jus to upgrade my phone to the newest version, though my computer does not recognise the file! what can i do??
(When I am going to upgrade my phone, should I turn it off?
Your PC won't recognise the file... Download the file in your PC>Move it your phone's SD... Now, Do you have a file manager installed in your phone? If not, list the apps you have...
Hi all im having the same problem as MoonDoggie and have tried canceling and installing again still isnt working :(
Have you tried the versions I've posted? Also, try opening the Market & keep your phone like that for some time, the Market should update itself...
hi Nirob yer i have grr its winding me up lol :p
Try clearing data/cache & Updates, Go to Settings>Applications>Manage Application & find Market(If it's not there, Press the hardware Option button then Filter>All) Tap on it & clear cache, data and Uninstall Updates
