Motorhead1991
Android Expert
DO NOT FLASH TO A GALAXY W! This is based on open source files specifically for the Rugby Smart
MH-Kernel 1.2
Here's the first of a, hopefully, long list of mods for The Rugby Smart.
Here, I added the following governors:
Smartass
SmartassV2
Interactive
I also tried adding init.d via busybox, however that needs more work.
These governors should help prolong the attrocious battery life associated with this awesome device.
You need Clockworkmod for this. Preferably Kemonine96's 6.0.1.1 as I verified that it works
To install:
1. Shutdown and reboot into recovery mode
2. Choose "Install from Sdcard", then "Choose zip from sdcard"
3. Scroll down to MH-Kernel1.x.zip and select it, choose yes and wait.
4. First boot may take a while (I though I had bootlooped). If this bootloops, follow steps 1-3 again and reflash the boot.img.
Once it is done booting, enjoy the new governors!
Old Releases:
MH-Kernel 1.0
MH-Kernel 1.1
MH-Kernel 1.2
Smartass
SmartassV2
Interactive
To install:
Old Releases:
MH-Kernel 1.0
MH-Kernel 1.1
