Root Updated Modem, but now going back with Oden?
EAD13721
I updated my Syndicate Rom but am getting fc's in different programs, or constant fc's or the the whole phone freezes. I'm going to wipe my phone back to factory for now before I choose if I want to reroot and put a new rom or do whatever. I just want a stable phone for the moment.
Anyways, to update my syndicate the other day I had to update the modem. Do I have to do anything now that I'm dropping back down to DI18 <I think? (Until it updates)
Thanks
Nope. You can keep the modem at EC05 and everything should work fine.
Kelmar, I was hoping you can help me. I rooted my daughter's phone with CWM5 and flashed midnight 4.2. Some of the apps like swype and launcher pro are force closing or not working and she's pissed at me. Is there anyway I can flash the new stock ROM while rooted with EXT4? What is the best and easiest way to get her back to stock so everything works but give her wifi tether access?
Did you wipe everything 3x? If not wipe everything 3x(data, cache and dalvik cache) and flash the rom again in recovery. That should fix the issue.
I wiped 5 times and flashed 4.0, then 4.2 over it. I kept getting a google error at sign in. I rewiped and reflashed and it worked on the 4th try. Weird.
Thanks for your help.
ya these new ec05 roms are kinda finicky, trust me you are not alone with that issue, i too had to do it like that;)
