junkie2100
Android Expert
i know not everyone uses windows, they should... but they dont lol
but yea here ya go i wrote these for those of you that have an alternate os so you dont get left out on all our fun
http://adf.ly/GjkvG
make sure you chmod a+x or use another method to make the one made for your system executable(not necessary, or possible in windows btw)
and i dont know anything about mac but in linux you will have to sudo both the chmod and the command itself
and i havent really tested them but they should work, so if there is something wrong let me know and i will fix it asap
and btw
USE AT YOUR OWN RISK, IF YOU BRICK YOUR PHONE THAT IS ON YOU
if you do mess something up we can try to help but there are no guarantees
but from what i can tell even if the scripts are flawed it wont hurt the phone
and if you would like me to test them for you and make sure they work feel free to buy me a mac lol
P.S. If someone could let me know for sure whether they work or not that would be wonderful. and the windows version doesnt count, that wasnt modified at all i just left it in there. i just wanna make sure there isnt anything wrong with the linux and mac versions, shouldnt be but ya never know
UPDATE
scripts should be repaired now. stupid me, i forgot to put "#!/bin/bash" at the top to tell the os what kind of command it was... guess thats what you get for accepting mac and linux scripts from a windows user lol, sorry about that it should work now. still cant test it myself but that seems to be the only error considering it worked from the terminal line by line
http://adf.ly/GjkvG
and btw
UPDATE
I used to spend most of my time troubleshooting windows, now I spend it troubleshooting other peoples windows
And thanks for thinking of us alternates...
