Root Updated to Gummy 2.0 and email not working?
I have used gummmy before and Kejar takes off the stock email. You can reload it in using the terminal.
1. Open the Terminal
2. type su (it gives you super user access)
3. Type gummytoolbox
4. select which apps you would like to reinstall
The ones that I had re installed were the email and visual voicemail, but it's easy to see what you would like reinstalled. Alternatively you could go with another email. The one I like is K-9 mail.
