Root Updating Axura roms
gwcaton
Android Expert
I bought a Vibrant with Axura 2.2 installed and I can't get several things to work like using usb to transfer items from my pc to the phones internal sd. Works fine for the external sd though and a couple of other things.
Anyway if I want the newest version of Axura do i install it as an update or as a new install ?
LOL never mind. things went from bad to worse and ended up doing Odin and back to stock eclair.
Now , do I try another custom ROM or update to official 2.2 ?
decisions , decisions.
Any recommendations ?
Stay away from official 2.2. It is not as fast, or even as stable as most of the current 2.2 ROMs available. Plus if you decide to root, it will be that much harder to do. Trust me when I say stay away. If you like touchwiz, try bionix V 1.(whatever they are up to now) touchwiz edition. On top of the current 2.2 ROMs out there being fast and stable(and much better than samsungs bloated release) there are now 2.2.1 ROMs surfacing that are 95% reliable. Give it a couple weeks and they will most likely be ready for daily driving. Or if you are feeling extra brave and want to run 2.3.3, CM7 has been released for Vibrant. It is still kind of buggy, but again... a couple weeks and I am sure it will be daily drivable. If you still decide to run stock 2.2 via Kies, still keep your eye on the community as I see a lot of very interesting things happening in the near future.
Thanks for the reply. I had pretty much decided against the official 2.2 after reading several posts on different sites. Think I will just sit tight for a bit and do some more research.
thanks again
thanks again
the newest axura i believe is 2.3.2 is awesome hot and fast with great themes,great battery life ....i find no flaws!!!! thanks master,annex and the other devs at devs4android!!!
Just finished installing it. So far so good !
