Help updating phone OTA, PLEASE HELP!
hi, dose anyone have the same problem i have?
ive been trying to update my note (gt-n7000) and from september as i heard about 4.1, went i try OTA, my phone now says, ''failed to update due to network or server problems. try software update via settings>software update> update, or try using pc kies later'' before it used to say, '' upto date''
dose anyone no why this has change?
thankz
thanks for replys. i have tryed from wifi, says same thing. when i conect it to kies and search for a updat it says 'GT-N7000' does not support initailization' :mad:
That's because no update is available. When you connect to Kies, it automatically searches for firmware updates for you. On the main Kies page it will tell you what the latest firmware is for your phone.
JellyBean is due at some point this month if sources are to be believed, as soon as it is, these forums will be full of information to that effect. However, the coming Jb update is only for the international carrier unlocked version of the Note.
If you Note is carrier locked, then it could take months for your carrier to release the update.
If you can use any carriers sim card in your phone then it is unlocked.
You have the same firmware as I do and at this present moment in time, that is indeed the latest official firmware.
