Help Updating to ICS issues with Kies :(
Liamalone
Member
Ello :)
I've finally been given permission by the Mrs to update her phone from GB 2.3.5. As it isn't my own handset I don't want to root or that and thought it should be fairly easy because of Kies, however .....
Kies fires up the following ''your device's firmware version is not supported to update firmware via Kies'' :( So much for the easy way!
Having searched the forum for the issue I couldn't find a reason for this error, the phone in question has never been tampered with so to speak. What's up? Any way of fixing Kies?
Phone info:
PDA: I9100XWKJ1
PHONE: I9100XXKI4
CSC: I9100O2UKJ1
Having Rooted my old Desire and my current One X I'm familar a bit with flashing and the like but after delving into ways of sorting this through flashing my head hurts lol, so much info to digest = confused :(
Thanks for replying :)
That chap's Kies guide doesn't seem to clarify why I'm getting this message on Kies, doesn't really mention it tbh. It seems to be more for folk who can't connect to Kies.
As for doing it with out Kies, is that by chasing down the correct ICS on Sam's site and using Odin? If so, does this affect warranty? Does it +1 on this ROM counter I'm seeing mentioned?
As for JB, am I able to flash the 4.1.2 UK one available on Sam's place - I9305O2UBMA1?
Many thanks chap, tis appreciated :)
edit: think I'm going to flash 2.3.5 from Sam again using Odin as some other dude did this and Kies worked thereafter, worth a punt.
Very quickly as I'm off out...
That, "chap", is me!
It is also emerging that sometimes vendors have been flashing phones with a different firmware prior to sale in an attempt to sell to a wider market and therefore upgrades via Kies are not possible, see next section.
I have rooted/unlocked my phone. Can I get ICS
You will not be able to receive ICS via Kies, the Samsung PC Suite, if you are rooted or changed your firmware/kernel and may receive the message, "YOUR DEVICE DOES NOT SUPPORT SOFTWARE UPGRADING VIA KIES" . There are also reports that people who have had their phones unlocked or repaired at a Service Point and re-flashed with different firmware are unable to receive updates via Kies. You will need to revert back to your original stock firmware. See here:-
Yes. Latest stock, UK, O2, Android 4.0.3 firmware is here.
However, this is for experienced and competent users, as it is not without risk, and will void your warranty if you are flashing a firmware other than that intended for your CSC code.
Will not affect flash counter.
The JB will void your warranty as it has only been released for Spain and China.
lol apologies 'chap', missed that bit about Kies as there has never been anything done to the phone, it's never been out of her sight so when I saw the 'rooted/unlocked' section title I went on past :(
As for the rest, I think I'm sorted for flashing the 2.3.5 Stock as a starter and have 4.0.3 already downloaded as a further step if required. I was just being nosey about JB, warranty voiding not wanted.
Many thanks again especially as You were heading out - I would've stalled until I got that stuff clarified so cheers :)
Also worth pointing out that this JB firmware is for the I9305 (Galaxy S3), not the I9100 (Galaxy S2), which you appear to have from the firmware code in your original post. Make sure you check this on any other firmware you flash with Odin
The JB will void your warranty as it has only been released for Spain and China.[/QUOTE]
So with me flashing the LS8 release it will have voided warranty etc and id be seen as a bad boy! but now i have gone back to 404 UK am i back in the "safe zone" ? :confused:
