Help upgrade camera recording
it5896
Hi, someone knows an apk to upgrade camera recordings ?
not a video conveter after recording, otherwise where can i find new drivers.
thanks in advance :)
Found...
search market for lgCamera...
you can change all sorts of settings for resolution/screen size etc....
Only half the settings will work because the GT540 will only support certain ones, the app is for all LG phones I think.
Only minor problem is that it saves in its own folder, which the standard gallery does not look into...
