Help upgrade eliminates Silent mode option
lowreed
After upgrading my DINC, the hardpress of the power button no longer allows me to set the phone to silent. The only choices I get are Power Off, Airplane mode, or Restart. The only way for me to switch to silent is through the settings, which is a PITA.
Any ideas?
Thanks very much.
Any ideas?
Thanks very much.
Just hold down the volume down button, and then tap up once. It's easier than going through the power button menu anyways.
