I'm having trouble upgrading my SD card to a bigger one. Every resource I can find on the topic says to just copy the full contents of the SD card to the computer, disconnect phone, turn off, swap card, turn back on, connect, and copy all files back to new SD card. I thought that Android 2.2 might cause a problem with this, because it can install apps directly on the SD card, but I found a post on these forums that said the copying steps above would still work.
Unfortunately, this didn't work for me. All of the apps installed directly on the SD card disappeared when I started up the phone with the new card, so obviously, something went wrong there with getting those apps to works.
Oh, and I was certain to show all hidden files, etc., before I copied everything from the old Sd card and back to the new one, so that isn't the problem.
Any suggestions?
Any suggestions?
