yep your phone is too old. you need to root it, get a custom recovery, and then flash a custom rom. the problem is that your phone is very old and even it is possible, the links to get a custom recovery and rom will most likely be bad. android developers usually will post the files on file sharing websites, but they usually will support them for only a certain amount of time as some of them costs money to host them.
you can use odin to flash both recovery and rom, but i doubt you will find any active links. do a search over at https://www.xda-developers.com/
if you find any links that works, please, if you can, post them here to help others who might have the same idea as your.
