schrodinger56
Am I correct in thinking that to have a hassle free upgrade from Version 2.3.X to ICS you should do a factory reset prior to downloading the update then another factory reset after you've downloaded the update?
Also can you still update OTA after doing the first factory reset?
Is it better to update OTA rather than use Kies? Also do the apps that you downloaded under 2.3.X still work under ICS?
Most of all is ICS worth it?
Thanks
Thanks
