upgraded battery
is there an upgraded battery i can buy? oem stuff
Seidio has a double-life/double-size battery out, same size/same life battery out, and is working on a same size/higher capacity battery. Seidio is high quality and generally decent pricing on batteries.
Other than that, you can look on ebay for a reputable seller...
OEM wise no there isn't anything. Like the other guy said if you want something that is upgraded then check out Seidio.
