Help Upgraded to Jelly Bean and now I can't open settings
LoganX
So today, I upgraded my Nexus S from ICS to Jelly Bean which I installed from the updates my phone received but then after it had upgraded, my power control widget wouldn't work and I was not able to go into my setting app. Whenever I try to click it, it gives me the error message "Unfortunately, Settings has stopped" and closes instantly. I can't factory reset it from the setting menu so I tried to factory reset it using the "Hard" method that was holding the volume up and power > Recovery way. After I had done that, it did reset my phone to as if i just taken it out of a brand new box but I still had the Jelly Bean and both my settings and power control still didn't work. How do I fix this?
I just went through my phone testing all the apps and widgets and realized that it was only the settings app, which also were in the power control widget, that wasn't working after the update. I have no idea how to flash, unlock, or do any thing on a android phone but I am a very fast learner. I'd appreciate it if someone could run me through step by step on how I can regain access to my settings. Thanks
First off, exactly which widget are you using, the power control widget that is included with Jelly Bean and ICS? Or an app/widget you downloaded?
Exactly what is the model you're trying to flash I9020a, I9020t, I9023?
If it's the included power control, then it may have been a bad flash (mine works just fine but Beautiful Widgets gets nuked when I power off my phone - todays update didn't fix that, but it fixed the toggle widgets).
I'd go into recovery, wipe data/cache, then reset and see again. If it still fails, you will need to find a full ROM online for Jelly Bean, rename it to "update.zip" and reflash from the Recovery menu. I haven't seen a full ROM yet, but it should be available soon. You might have to forget about the power control widget if you can't fix it with a wipe and reset, at least until a full ROM is available.
To answer your first question, it is the power control widget that came with the ICS i believe. Since I got this phone off someone, so i'm not sure if it was already flashed to ICS or if it was Gingerbread before. All I know is that the person factory resetted the phone from settings and it was ICS.
As for the model, its GT-i19020a. I'm not sure how I could have had a bad flash since the update I downloaded and installed was straight off from a update on the phone. I tried rebooting my phone to see if it would go away but it didn't.
I have already gone into recovery, wiped data/cache, and restarted the phone and no luck. It remains in JB along with the settings problem. I am a complete noob with android phones currently so I may need some help. I'll try to find a ROM for JB.
I found one but every time I go into recovery to update it I get:
-- Install /sdcard ...
Finding update package...
Opening update package...
Verifying update package...
Installation aborted.
After many hours searching through multiple forums, I managed to solve the problem. Thanks for the help bfksc.
