After flashing the radio; Kies will pick up the phone and let you update to UCLF6 which is ICS for AT&T Note.
LAST NOTE: Do not uninstall Kies! The new firmware requires that Kies and the drivers be installed in order to access your phone's internal memory through Windows Explorer (shows up as a device.) If you try to use the drivers from the previous firmwares, it will fail to install and your phone will not connect to the computer. It took me an hour to figure this crap out until I realized that the new Kies (that you have to download in order to upgrade to ICS) has a new set of USB drivers nested inside it.
