Switching from the Optimus V over to the Evo V 4G and will be migrating my 32GB card over to the Evo. I do believe I created an ext partition on the sd card when I installed CM10 Jelly Bean on it as, from a forum tip, the new Android OSs can handle app movement automatically to / from the SD card (no need for Apps2SD) with said partition. What do I need to do with the partition on the SD card before I install in the Evo to ensure there won't be any problems? Can I simply delete it before installing and will the ICS on the Evo recreate it and use it?
Also, the Evo has 4GB onboard, right? Do I even need to be concerned with this setup?
