Root upgrading to ji6 manually gone wrong!
so i got my vibrant, rooted my phone, and decided to update my phone through odin and the ji6 file provided. My phone doesn't turn on now. All it shows is a cell phone, exclamation point, and a computer. Someone please help me.
welcome to the forums!
try this, i had the same problem you did
if you get this phone exlamationpoint computer screen, a ''soft brick'' try this method
1. Take out battery, put it back in. (to turn the phone fully off)
2. Don't turn it the phone on!
3. Plug the phone into your PC, do not hit the power button!
4. See if the phone shows anything on the screen (powers on its own when plugged in)
IF the phone screen does 'turn on' after being plugged in without you hitting the power button, so far so good.
5. Now while it's on like this, hold the volume up and volume down buttons.
6. Hold the power button as well as the volume buttons until the screen goes black.
7. As soon as the screen goes black, let go of the power button! But DON'T let go of the volume buttons!
you should then be back in to download mode. ODIN AND ENJOY!
well i would try mini kies but it does not let my phone enter the main screen it loads the samsung vibrant name then the galaxy s. Once that happends it just stays black!
dude Ghost you saved my life i almost shitted myself cus i thot i bricked it cus while it was downloading odin froze and it didnt odin or whatever so i had to take it out and i got that exclamation mark thingy
