uploading pictures help...
Ilphay
I am currently on vacation and I do not have service where I am, and no acces to wifi, or my own computer. When I mount my phone to the computer to get the pictures off the camera, nothing happens. On my own computer I usually just mount it and a folder pops up on the screen and then i go from there. is there anyway i can transfer these pictures from my phone to computer?
It should pop up, but go to 'my computer' or whatever it is called on what type of computer you're on and see if your removable drive shows up there. After you mount it of course. I am not too familiar with your situation, but maybe the computer you are using blocks people from connecting external devices as a precaution?
does it have the correct driver install on that pc?
did it even search for them...
crap you said it did nothing, hmmm...
The computer probably just has auto-play disabled, so you'll see no popup. You should still see it listed under My Computer though. You shouldn't need any drivers to just access the mounted drive, I believe they are only needed for tethering or ADB access.
