Help uprade from android 2.2.1 2.33
buyom
how to upgrade my x8 to android 2.33?? i'm currently using android 2.2.1
mod version:floyo by Racth
buid number:0.20..
please,i need your help... as soon as posible...:confused:
thanx..i've did it last night..it work greats!.. XGin4.0... what about XGin 5.0? it is better than 4.0?
I would suggest to stay on 2.2.9 FroyoBread ROM, becouse I heard, there are still some issues with LED notification, so it drains much more battery.
This is the best ROM atm imho.
the camera can use..but in a low resolution.. but,it looks great..
2.2.9 FroyoBread ROM not have any problem?
if i want to upgrade my x8 ROM from 2.1 eclair.there have any problem after upgrading ROM?? i just try to upgrade but it have problem..always reboot...then i have to restore to eclair back...actually i from malaysia...do u have any suggestion..
yg saya guna skrang adalah froyobread..rom ni sgt2 stabil..try...ikot step by step..xde msalah..
ak dah try upgrade dh....setakat nie ok la gune 2.2.9....tpi kdang2 bile btery life mkin kurang....msti reboot....leh tolong x..
When you have backed up your phone then follow those steps one by one ;)
1. Create a new folder on your desktop and rename it as per your choice.
2. Now move the downloaded “Android Froyo Custom ROM” to the renamed folder.
3. The Custom ROM is a RAR archive so you need to extract it using WinRAR.
4. Now connect your Sony Ericsson XPERIA X8 Phone with your PC via USB cable.
5. Select “Open Folder to view files” in the Autoplay box and then click on OK.
6. Now Go To backup folder present inside the xrecovery folder.
7. Copy “Android Froyo Custom ROM’s” folder to backup folder from renamed folder.
8. When it’s done, disconnect your phone from your PC.
9. Switch Power off your phone after a while switch power on again
10. and as soon as the Sony Ericsson logo flashes on the screen start pressing the back key continuously.
11. This will take you to the Xrecovery menu.
12. Now Select “Backup and Restore” in the Xrecovery menu click on restore( there is 2 files the Backup and the "Android Froyo Custom ROM” file ) select this last one
13. It will Ask “Are You Sure”. Select “Yes – Restore”
14. Now it will start installing “Android Froyo” on your XPERIA X8. Be patient, it will take some amount of time.
15. After five or six minutes installation gets completed and a menu comes in front of you. Select “Reboot” From That Menu and Press Enter.
16. Your Phone will reboot and you will see the change.
and voila Android Froyo get’s installed on your phone. Enjoy :)
thanks........
after i up date to this froyo..i hve big problem i think...coz my android cant on...the sony ericsson logo only show..i waiting for 6 or 7 hour..but nothing different...why??
(sorry for my bad english)
thanks........
i don't think you routed your phone before isn't it ?? the Phone need to be rooted first :p
by the way your english is fine :cool:
