Actually the home screen can rotate depending on Launchers. TW can't, so if it is rotating when you are using stock launcher, then it is a bug.
1) Find out if you installed any apps that might be buggy
2) See if clearing data from the launcher can help. But this would revert your settings to the original.
Cheers
