hello androind user and admin for this phandroid..mysamsung galaxy ace has problem with the application phone (process com.sec.android.app.dialertab) has stop unexpectedly..
Hello and welcome aboard. That error message could be caused by one of several unknown problems - one of which is a conflict going on with installed applications. What I would suggest you do is to clean the device from any or all corruption that might have incure from installation.
Hopefully resetting the device to its default state should get things running back to normal. Also, check inside your device's support forum for some cool info and tips on your device.
