Root URGENT HELP...please>?
lesapt59
I flashed to CM7 yesterday, coming from a V11 of Romkitchen
I had no signal, imei and number...so I wanted to flash back to a 2.2 ROM...unless someone can help me find out why this happened
Found out CWMR 3.x only allows 2.3+ to be flashed
I hear of this HBoot on other phones that allows them to revert back to CWM 2.5.x, but I can't get into that
So, how can I revert back to CWM 2.x on the Cappy?>?
Thanks:o
Thanks:o
in the ROM Manager app theres a setting to flash CWM Recovery, obviously, but at the bottom, theres an option to flash an older version of CWM instead. try flashing an older version(2.5.x) from that menu
Thanks:o
Did you run the EFS backup before you flashed CM7? It's what stores your IMEI and number.
As for the signal issue, you probably flashed with your phone still plugged in.
