Urgent! Need to unroot without a usb cord!!
If it doesn't work, then there is something else to do to make it work but I cannot remember what, brain fart right now, but hopefully LBP or RB will chime in and post, I will look around this morning if I find it, in the meantime if it fails the first time, do not reboot try again and see if it works, if not then try restoring a sense backup and see if it works on a sense Rom, report back
Crap it's not working
Try backing up your card on your computer. Then format the sd card(I used Amon ra recovery to format). It worked for me when I had tried everything to get my phone to recognize the HERCIMG.zip after I formated it found it on the first boot.
I knew I had read what you wrote but could not for the life of me remember, LOL getting old sucks
Yeah. That is good information to have.
I never had an issue flashing the Android 2.1 RUU .zip file. It is always good to know a few alternatives.
I used this....adb shell reboot oem-78 -- that will reboot your phone in to RUU-ready fastboot. If you had the RUU still open then close it. Then open it and try running again....When my hero was having problems with RUU's and it worked obliviously.
