Hi friends
im new here so this is my First post and what i want is help from any android expert in solving my problem. see i recently got the HTC one X plus and unlocked the bootloader, and installed clockwork mod recovery and rooted my phone. now when i receive the offical jb ota update 1.17.401.1 , i cannot update it and it says error and i abort the installation and then reboot the phone in clockwork mod. and by the way all this unlocking and rooting is done thanks to Hasoons2000 tool kit, bless that developer who made this toolkit. so after researching reading many forums and i find out that we have to use stock recovery image for htc one +. to fix the problem , i cant find any One X + stock recovery image all i can see are htc one X stock recovery image. but i need the one specific to my phone model.
Also it would be of great help if you show me the process of using stock recovery on hasoons2000 toolkit for oneX+
Since i dont want to risk bricking my expensive phone. so guys if you have the solution to my problem please do help me out.!!
trying to make the OTA work can be very fustrating,and there is nothing special about it. running the ruu utility from your PC is more controled,more stable,and will get you the same end result.
