Help Urgetnt help needed guys... please help....
ankitnice
I tried to root my phone using one of the .apk apps for z4root in one of the threads here.... then i ran the app and phone is now rooted... however, it is bringing up frequent popups of "sorry! the process com.android.phone has stopped unexpectedly...Please try again..." Is doesn't even let me get into the settings or anything. Also, the mobile network is going off and on. I have even unrooted the phone but can't get into settings to uninstall z4root.Tried restarting the phone and every basic thing. But couldn't do much. Please help me out.
Oh i experience that, when i was updating
everything was force closing.
The fastest and easiest way to fix the problem is to
Hard Reset it.
You can use this technique to solve
= Remove Wrong trials in entering password
= account blocked and no access to menu
= to remove all your data from phone
= to remove viruses or malware application
= to speed up your device.
LG Optimus GT450 Hard reset is easy and can be done by anyone.
Follow this easy steps
1) Start your phone [phone must be started with or without sim]
2) Press volume up button + home button + search button
[Location of volume up button is on right side, location for home button is on bottom middle button of home screen and search button is right side of phone above camera button]
3) Keep all those button pressed at the same time for 5 second
4) Phone will ask you for " Are you sure you want to factory reset?"
5) Press yes and wait for 1 minute, Phone will hang first and than restart after sometime.
6) You've done resetting your GT540 successfully
Ohh Dude... What a gem you are... You sorted this out for me... Am really really thankful to you... i just wish I had more than one thanks buttons to have been able to thank you....
Thanx again.....
