solidkevin
So I have a US Hero, and am using ATT, anyone know the 3G settings? Would be much appreciated! Thanks.
I'm assuming by "US Hero," you mean Sprint Hero? If that's the case, it wont work with AT&T because AT&T uses GSM while Sprint uses CDMA.
If it is indeed a GMS Hero (in which case it is not a US Hero whatsoever), you can only use AT&T 3G if you have the Telus version of the Hero and get it unlocked, in which case, it will automatically use the 3G connection whenever it's available.
All other GSM Hero's can only use EDGE on AT&T (as well as T-Mobile).
I thought we already went over this....
http://androidforums.com/htc-hero/30060-just-got-my-hero-no-market-kinda-laggy.html#post209454
