usb cable/usb port/usb adapter
uknow
Ok I have a pandigital novel 7 inch white it does not have a usb port I was woundering if I could get a adapter that will allow me to plug my usb into my s3 then gat the usb double female adapter and plug the usb for the tablet into it so I can use internet through easy tether will this work
Ok step one (the first pic is s3 cable) connect to adapter which is pic two step 2 connet tablet usb to adapter (which is pic 3) step 4 plug all in to the devices and install easy tether to tablet does anybody think this will work
I'd say it probably won't work, the tablet would have to support that type of Internet connection, which it probably doesn't... You would be better off using a wifi tether option :)
Thats the thing I dont want to root my s3 really and I have T-Mobile which I dont mind paying for tether but I do mind droping unlimited todo so which is the way T-Mobile does there prepaid so im stock lol easy tether will work as long as I can connect the two together I just dont know how seeing the novel dont have Bluetooth the only other way would be this by the way on this tablet the usb cable is not for charging it has another spot for that the usb is strikly for connecting to computer for data exchanging
