I've had my Wildfire S for several months now, and this is the first time this problem has arisen. When I connect my phone to the computer using the USB cable, it doesn't prompt what type of USB connection I want to use (the setting that it should ask a connection type is turned on, standard connection is set to HTC sync at the moment, and USB debugging is turned on aswell)
The computer doesn't recognise any hardware or storage device either, and HTC sync can't find the phone. I've tried to restart both the phone and computer, and also tried to re-install HTC sync without any results.
As I mentioned before this is the first time I experience this problem, before today everything worked perfectly (I last synced about a week ago)
If anyone can help me fix this issue, I'd be very grateful!
