Ya, but it actually does work for the most part. Heavy use such as streaming video over a tethered connection will typically make it flatline or decrease (does that on OEM charger for extreme use as well). It's about halfway between USB and AC charging strength.
Do you think I am endangering my battery health? I wish there was some good technical info out there about this...
Here are the cables I bought:
10ft
6ft
OEM setup
I use by 700mA blackberry OEM AC charger too which works quite well, and my verizon car charger that I bought for the old blackberry long ago, which works fine too.
However,
in use, the only charger that keeps it from dropping for the most part is the stock AC charger setup. On my car charger, even a voice call will make it flatline or drop.
This is borderline off topic, sorry, should be posted in a new thread about charging-general...
