dawnlauryn
Of the MANDATORY Features I miss from my Motorola Razr, this is the most important: There is no option to set USB connection to Charge Only! YIKES!
I have contacted both Samsung and Verizon for support. Both say it's not available on this model and I should shop in the app store for an app (which IMHO is ridiculous, phone security should be a top priority). I've tried USB Lock Lite, which looked like it worked at first glance, then I checked on my phone a few minutes later and sure enough, you could access all files to the phone from my windows PC (which is charging on an office network). It's unreliable, so that was a bust.
Also, I'll throw these out there too, in case anyone else switched over from a Motorola Razr Maxx...
- Has anyone figured out how to secure their Note 2 when charging via USB Connection?
- I miss Sleep Mode (conserves power, deactivates notifications, allows for the only sound to be PHONE, so it's doing it's primary job of being a phone). All I know to do to achieve a similar feature is just always keep my sound & vibration off on my notifications (which sucks) and then to close all tasks (see next).
- I'm not crazy about the way you close apps on this phone, but at least I found out how to shut them all down without having to restart the phone or use the task manager: Just hold the center (verizon) button then select the Remove All menu option on the lower right of the phone.
