Help USB/charger port no longer recognized
aakyl
It looks like my charger/usb port went bad. I just called up VM and they said I am no longer under warranty. I am still in the $25/month plan and I want to keep it. Anybody know what my options are? Thanks in advance.
I have something like this and the same problem as you, some people here say its the battery and that a fresh one should fix it.. Either way I would suggest you look at one of these..
Code:
http://www.ebay.com/itm/2x-1650mAh-battery-Multi-Function-Charger-4-Virgin-Mobile-Motorola-Triumph-WX435-/280920016841?pt=PDA_Accessories&hash=item41682347c9#ht_2677wt_1139
